LS1 Rpm Limit stuck at 5500rpm t400
Just had an LS1 Powered Toyota Hilux come into the shop that had already been tuned and limters have been set very high on a stock motor but it will just keep cutting out at 5500rpm.
Stock LS1 with a built T400 and 35inch mud tyres, only made 225rwhp when I was done with it at 5100 rpm.Is this due to big tyres?
No speed signal from gearbox
Engine runs perfectly well, I just cannot find out why its limiting at 5500rpm.
Attached file is how it came in.
Any help would be great.Scotts,ls1hiluxstock.hpt
turn off trans abuse mode, zero all engine Torque management and set start up modifier to your desired limiter
