Results 1 to 7 of 7
Thread: Faster rev limit for an LS9
    Jul 2019
    15
    I use an LS9 on a drift car, the stock rev limit settings are very unsuited for drifting as it's very slow & has a some sort of a delay logic, it's like you lift of throttle for 1-2 seconds & that kills the car's momentum as the car drifts at full throttle. I heard about a remedy for this specific issue, can someone please list the steps needed to improve the rev limit?
    I really appreciate your help
    7,600
    Post your tune file.
    Jul 2019
    15
    I appreciate your help
    Nov 2009
    All Around
    3,149
    change the control method probably set to ETC
    Jul 2019
    15
    You mean disable ETC? as it's enabled in my current tune. I believe in order for this to work the "Cmd Torque Delta" table would have to be modified also, but I'm not sure how!
    I'd appreciate your feedback
    Jan 2014
    Australia
    1,978
    good read here about it, post 12 on has a adjustment
    https://forum.hptuners.com/showthrea...er-rev-limiter
    Jul 2019
    15
    I also found this thread
    https://forum.hptuners.com/showthrea...ge+rev+limiter
    The solution in the above thread was by disabling both spark & ETC & enabling fuel cut & further by modifying the 'Cmd Torque Delta' but the pic showing how to modify the table was erased from the thread!
    I'm positive that many had properly set the rev limit for a drift car. Any advice what's the best approach?
