Results 1 to 5 of 5
Thread: Critique my tune / adding more boost (LLY)...
    Apr 2014
    12
    I have a 2005 CCSB 2500 6.6 LLY and 5 speed Allison trans. It's pretty stock except for a AFE turbo mouthpiece, pcv reroute and a 4 inch catback (stock downpipe).
    I have tuned it using some of the repository tunes but I'm looking to clean it up some. It is a little laggy and does smoke a bit excessively (quick throttle change, downshifting to pass, WOT seems decent.. just a little haze). I'd also like to increase boost a few lbs, though i don't know if i am doing it right or not. I added some in the desired boost tables and just get underboost codes..
    So here it is, any and all opinions are appreciated!
    Jun 2018
    Albuquerque New Mexico
    78
    Quote Originally Posted by PayUpSuka View Post
    You're confused on your boost tables. High alt is for high altitude, you will see less boost when compared to low alt. Same goes for your torque calculation tables under torque model. They are backwards, You'll make more torque at low altitude vs high. The air is thin at high elevations which is why you should see your turbo vane position go up from 32% to 41%, but again they are in the wrong tables...... Where did you get this tune? If i were you i'd start with your stock tune and go from there.
    Apr 2014
    12
    Quote Originally Posted by JaegerWrenching View Post
    I actually got it from the repository. Apparently it's shit.. lol
    Do you have a file I can compare to?
    I do have my stock file. I am finding little to no support for these engines/ecu's on HPT.. everything is EFi Live.
    Jun 2018
    78
    Post your stock file and ill look at it and help you out. I want to see what it looks like compared to this tune.
    Apr 2014
    12
    stock tune, ecm only.hpt
    Here is the stock file. It's ECM only as no matter how many times i've tried, it always fails the TCM.
    Thank you! I really appreciate it! I do some light tuning on gas engines but this is my first diesel. Had extra credits, figured I'd tinker with it some and learn a new platform.
