Results 1 to 9 of 9
Thread: 2014 ctsv suddenly really rich while in PE
    Feb 2018
    824
    Took my car out and logged it in this hot ass weather and noticed while in PE it's running super rich. Every other time I've logged my actual has matched my commanded within 2-3%. This isn't the rich after flash issue as I drove about 100 miles the previous day and didn't reflash anything. when you look at my WOT areas i'm running deep into the 10s for my afr. Could this possibly be because I haven't adjusted the injector tip temp table for my ID850 injectors? Please ignore the knock in the logs...i've taken care of that
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    Rich after flash is just one of the symptoms. https://forum.hptuners.com/showthrea...h-after-Flash/ If you have not taken into account injector tip temp while tuning MAF and VVE then you have issues.
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
    Feb 2018
    824
    Quote Originally Posted by jsllc View Post
    No I did not...everytime I was tweaking the maf and VVE I just made sure ECT was at operating temp
    Feb 2018
    824
    If i go through the same process that you came up with (zero out injector tip temp at operating temp, then take that value and subtract it from all of the higher cells) I'll need to completely retune my MAF and VVE correct? Since it looks like there is pulse width added at normal operating temps in my tune
    Sep 2015
    Bozeman, MT
    701
    So assuming your car runs in the 131 or 140 cell normally. You would want to filter any MAF value that does not fit in that range. Once the adjacent cells are calibrated where they also have no MAF adjustment required you could then include those in your MAF filter.
    Feb 2018
    824
    when you say maf value you are just referring to your STFT right?
    Sep 2015
    Bozeman, MT
    701
    No. MAF. The air/hz values in the MAF calibration table.
    Feb 2018
    824
    Ok, so what error % are you applying to the Injector tip temp to get the higher cells in line? Sorry but I'm confused on what you are saying.
    Oct 2019
    285
    Why do these post just suddenly end??????
