Results 1 to 1 of 1
Thread: Stock File Request : 2005 Chrysler Town and Country
    Sep 2015
    26
    Here is the info form the PCM I have:
    Code:
    Creation Date: 7/22/2019 4:56:13 PM
    VIN: 2C4GP54L95R119495
             2005 Chrysler Town & Country Touring, 3.8 L, V6
    Hardware: NGC3, Dodge
    Serial: TEH19030XF7I
    OS: 04748537AH
    Hardware: NGC3X, Dodge
    OS: 05094104AD
    My problem is that this is a remanufactured PCM and it clearly doesn't have the correct OS loaded in it as it has turbo tables along with several important diagnostics disabled. My issue is the Speedo doesn't work but the TCM see's the output from the VSS and so my transmission works fine. I'm thinking it's something wrong with this calibration and it's something I can't see in the VCM Editor. I'm attaching my file I pulled from this PCM as well. I just want to flash a stock file on this so it runs correctly. Thank you for anyone willing to pull this file for me.
