Results 1 to 4 of 4
Thread: How to assign certain cylinders to an o2 180 degree headers
    Jul 2019
    2
    Hi guys I have a set of 180 degree headers in a Porsche 911 that?s got an ls1 swap. Question is with each header being connected to both sides of the engine can I assign 2 cylinders from one bank and 2 from the other to one o2 and vice versa so I can still run my narrow bands and how do I set this on HP I remeber seeing back in the day a post the said you can add cylinder to bank map. cheers Reece
    13,564
    We can't do that, that's not something you can program.
    Seems your only option is to pick a cylinder on each bank and weld on a bung into that runner on the header if you wanted to run narrowbands. It's not ideal but could work.
    Jul 2019
    2
    Really I have read another post on here where a meme we had 180 headers and said that he could switch the 2 center cylinders with the opposite side?
    13,564
    How could that work?
    The o2 sensor can only trim fuel for one side. How could the computer know that cylinders 2 and 8 are on bank two but 4 and 6 are plumbed into bank one?
    We don't even have individual injector control, it's going to try and give each injector the same amount of fuel to inject each time.
