this is a 2016 s550 with a Gen 5 stage 2 whipple setup 1050id & a JMS fuel pump voltage booster 93 fuel
still learning my way through with these s550 but saw the knock going into overtime when pedal at WOT..data log showing how erratic & have never seen this before has anyone else experience this ?
Throttle is fully opening now, but you are still playing with fire.
It looks like you reduced the knock sensor sensitivity or something, because they are essentially offline.
Above 6500 rpm, for some reason your injector PW falls way off. I'm not sure how it is appearing to maintain EQ with such a drastic reduction in PW. It is right at this point that your MAF signal shows flow reducing, despite WOT throttle and increasing rpms. Not sure if you are pegging the transfer function or have some sort of mechanical limitation. Maybe a speed limiter, even though the logged sources show no limit.
