Results 1 to 2 of 2
Thread: Some OBD values sometimes not recorded
    Jul 2019
    3
    I have bluetooth OBDII device paired with android phone. Last time I've recorded ride and everything was good. Then I've turned off engine and application for 30 minutes. Then I've made second recording and when I was rendering the video I've found out that in second session some OBD values were not recorded. Most importantly throttle is zero, but also other values - last 4 columns are all zeros ("Throttle Position (%) *OBD","Engine Coolant Temp (C) *OBD","Intake Air Temp (C) *OBD","Intake Manifold Pressure (kPa) *OBD").
    Do you have any idea why the same hardware and software didn't record the same data? Thank you
    Here is header and sample line from session 1:
    Code:
    # RaceRender Data: TrackAddict 4.3.6 on Android 9 [HMD Global Nokia 7 plus / Qualcomm Technologies, Inc SDM660] (Mode: -1)
    # Vehicle: 2009 BMW
    # Vehicle App ID: ......
    # GPS: Android; Mode: Android
    # OBD Mode: BT (OBDII); ID: "ELM327 v1.5"
    # OBD Settings: AP1;AF1;RPR0
    # User Settings: SL1;U1;AS1;LT0/1;EC0;VC0;VQ3;VS0;VSOIS0;VIF1
    # Device Free Space: 10982 MB
    "Time","UTC Time","GPS_Update","GPS_Delay","Latitude","Longitude","Altitude (m)","Altitude (ft)","Speed (Km/h)","Heading","Accuracy (m)","Accel X","Accel Y","Accel Z","Brake (calculated)","OBD_Update","Engine Speed (RPM) *OBD","Vehicle Speed (km/h) *OBD","Throttle Position (%) *OBD","Engine Coolant Temp (C) *OBD","Intake Air Temp (C) *OBD","Intake Manifold Pressure (kPa) *OBD"
    1253.985,1564071545.985,0,0.000,48.0575918,17.5722360,155.5,510,119.7,232.4,3.2,-0.13,-0.25,0.13,0,0,6346.500,120.000,88.627,99.000,35.000,0.000
    Session2
    Code:
    # Device Free Space: 7033 MB
    577.262,1564074411.262,0,0.000,48.0530903,17.5684133,157.4,516,160.2,203.2,3.2,-0.03,0.00,0.03,0,0,6387.000,160.000,0.000,0.000,0.000,0.000
    Jun 2019
    8
    Quote Originally Posted by rrrado View Post
    Code:
    # Vehicle: 2009 BMW
    Session2
    Code:
    Autoguysland introduces some function of OBD scanner. You can visit Autoguysland website and read more
    May be some problem when OBD transmission data
