Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: TCM read erro loc 64800
  1. #21
    Oct 2005
    St. Croix Falls, WI
    57
    As far as I know it is a stock PCM. I bought the truck used, so cannot be 100% certain.
    I have a trailer brake controller on the truck, I infomred the guys HP, did not concern them. Only other item I have is radar detector. Disconnected that to make sure it was not causing some cosmic interferance.
    I have nothing else connected to the truck, stock stereo, stock batteries, stock motor and tranny.
    Working on a few things with them, so we will see what comes of it.
    Thanks!!!
    Jon
    2012 Ram 3500 6.7 Cummins with Banks CAI, intake tubes, intake horn, grid heater/EGR/DEF delete, 4" Straight pipe
    2017 Jeep Wrangler Rubicon Unlimited, Stock - but looking to change that
  2. #22
    Tuner Dynomike299's Avatar
    May 2006
    Connecticut
    74
    I pull the TCM fuse for 30 sec and the tune goes with no issues????
    Shop Owner, Tuner and Headache Specialist
  3. #23
    Oct 2005
    St. Croix Falls, WI
    57
    Quote Originally Posted by Dynomike299
    What do you mean you pull it for 30 seconds? right when you start tuning? When it begins to error out? Can you explain a bit more?
    Jon
  4. #24
    Dec 2006
    Washington State
    96
    dang never seen this before. Still having this issue also Only fuse that makes it better is when I pull the Trans fuse and it is not read at all
    Maybe we could add a box to not read the trans? it really cuts down on read and tune time!
    Ellis
    Speed Secrets
    95 Z28 18* LTx
    95 Z28 LSx converion
    03 CCSB 4x4 D/A
  5. #25
    Jan 2007
    30
    I am having this issue also. 04 k2 LB7.
    I fail reading at the same location using .18 HPT software.
    Actually I fail consistantly at 64C00, Every time on the trans controller.
    For what I would like to change I guess I can just pull the tcm fuse but it bothers me that I can not read the TCM. I am thinking about making a jumper wire for the star connector to connect pin 2(ALDL) to the ECM and TCM to eliminate any possible interference. Need to pull diagrams to sort out but not sure what to try next. Any suggestions?? I was able to program with a tech 2 without issue.
    John
  6. #26
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Have you tried reading in low speed mode?
  7. #27
    Jan 2007
    30
    I have, oddly enough it fails in a different location. Actually reads a little bit more.
    First attempt with a 2.8 ghz P-4 laptop. USB 1.1
    Going to try my other laptop today.
    1.7 ghz P-M USB 2.0 to see if a bigger data pipe has any effect.
    John-
  8. #28
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    I wonder if you need a usb 2.0. for it to work?
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
  9. #29
    HP Tuners Support
    (foff667)
    28,265
    na 1.1 should be fine as long as your running the latest public version.
    Any inline modules, onstar or anything that might be on the same databus as the pcm/tcm?
  10. #30
    Bill is there anyway you guys can give us a check box or something so we can choose if HPT reads the TCM or not?
  11. #31
    HP Tuners Support
    (foff667)
    28,265
    Already in the main request thread http://www.hptuners.com/forum/showthread.php?t=6619
  12. #32
    Jun 2007
    Mn
    240
    Good add.
  13. #33
    Jan 2007
    30
    No difference with the USB 2.0
    I saw some previous post's with overrun issues, hoped this would do it.
    ECM dumps fine it's the TCM I have issue with.
    If it helps anything here is my info log-
    John
  14. #34
    Jan 2007
    30
    Tried again with the 2.8 usb 1.1 machine in High speed.
    Failed- again in the TCM. This time I consistantly received the error-
    Invalid byte count in block transfer.
    I did however manage to download the second try turning off high speed transfer.
    23 minutes for an ECM - TCM download.
    Question- I have lost faith in my ability to reliably read write this combination.
    Bottom line I am afraid to do a write, I am a little gun shy because I have scrambled multiple computers in the past ( I will also add Not using HPT) but been there before. If I can not do a reliable read, I am not going to do a write. I don't have any duramax bins to fix things with if I get into trouble.
    Any suggestions for reliable comms?
    Prey and use slow speed??
    Thanks for any suggestions
    John-
  15. #35
    you should be ok on the write, it's just the read that gives problems. i'm going to look into it when i get a chance.
    I count sheep in hex...
  16. #36
    Jun 2006
    eastexas
    104
    Seems that reading in lowspeed mode would do the trick.
