I'm just beginning with HP tuner. So what I got is I installed a 2009 L76 and 6l80e into a 2009 Toyota Tacoma. All of the emission stuff and VATS is deleted. We didn't have stock MAF or tube that the sensor sits in. The air intake tube size is 4" and it has a ls3/ls7 MAF installed. I set up IAT sensor Cal, IAT 2 sensor Cal, and airflow vs frequency to a 2010 Camaro specs. I switch the power and ground locations on plug. Also changed timing on high and low octane under spark to 2010 Camaro specs. It will start but then dies after about 10 seconds. I went back in and save tune then changed everything under engine> airflow to 2010 Camaro. It runs now but IAT temperatures go way above 110 degrees and if you snap throttle a few times then it locks out throttle pedal. I did do a record of log and will try to attach to this. I don't know if I went too far on the airflow settings or what. Also right now it has open headers with o2 sensor tied to bottom of headers. I think it maybe running too lean and that is why it shut throttle off. If someone could tell me what my next step should be I would appreciate that.
