This is E40 pcm
at 6000 rpm WOT and 169-170 kPa in both logs, can see its 8.11 target in one, 7.97 in other (10.11 stoich value at alcohol content in first for 1.246 PE ratio, 10.06 in second for 1.262 PE ratio)
Standard PE table is 1.19, but it should select the richer of the two PE tables and go off what is in Boost Enrich which should be 1.29 PE ratio
