Results 1 to 3 of 3
Thread: Question about AFM delete
    Tuner in Training CoolBlueSS's Avatar
    Mar 2007
    Denton, TX.
    34
    I'm working on a 2012 Silverado 5.3 LMG, and doing a complete AFM delete using L96 6.0 cam and valley cover. I'm about ready to pull the trigger on the MPVI2, but have a question. When disabling AFM do you need to turn off all codes pertaining to that system, or can you just disable it and be done?
    TIA
    13,564
    Disabling the codes should be done as well.
    If your plan to keep the VVT using that 6.0 camshaft? I'd rather just remove both if you plan to replace everything.
    Mar 2007
    Denton, TX.
    34
    I'm keeping the VVT. My thinking was to keep it simple, and not have to worry about changing sensors, ect. Doing this for a friend that has had the lifters replaced once, and it's starting to tick again.
