working on a 6l 2500. ive deleted the emissions and monitors reported to pass. ive added timing to spark maps sense the truck primary fuel is 93 oct. changed full throttle enrichment tables for 12.5ish afr request as soon as possible. minor trans tweaks for firmer quicker shifts. ive also added a brake rev launch control too and a hard cut rev lim. tested all changes with good results on the street and dyno. ive plaid with a few more tables sense with toque limits. maximum requested torque was set to 350ft/lbs so i maxed that value and set ETC TPS Max vs. RPM vs. % Max Available Torque table to linear values. my question is will this make throttle more lively? i wont have a chance to test until monday.
thanks
