Hi guys!
2010 Camaro L99 with CAI, LTH, 3.91 gear ratio.
I have followed this good tutorial https://www.camaro5.com/forums/showthread.php?t=196696 updated with last HPTuners software v4.4.4, but I have a problem in the first step (Tune VE table).
I had set the tune file to scan only SD with MAF disabled, but in the VCM scan log I can see the MAF sensor the same that falsify the result. I supposed to read zero
Tutorial settings for disable MAF:
Engine Diagnostics -> Airflow -> MAF Frequency Fail High = 1 Hz
Engine -> Fuel -> Cutoff, DFCO -> "Deceleration Fuel Cutoff" -> Enable ECT = 493 ?F
Engine -> Fuel -> Power Enrich -> "Enable" -> MAP = 75 kPa
Engine -> Fuel -> Temperature Control -> COT = Disable
Can anyone tell me why I can read MAF that I supposed was disabled ?
