Results 1 to 5 of 5
Thread: 2017 mustang gt dyno
    May 2019
    14
    hi, i tune a mustang yesterday stock put 332hp on dynojet, i tune just timing and put 356hp but the car does not want to make any fuel changes at WOT, in one of the files i changed the minimum lamda to .87 then the car give me a perfect 12.6 afr line on the dyno but the HP going down to 327hp, this is the file for the 356hp if somebody put me in the correct direction it would be great
    mustang 2017 cuba 2.hpt
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    .850 is a good lambda target
    If you want any kind of real help, post your log file (and dyno sheet)
    May 2019
    14
    here is the first datalog and the dyno graph
    Nov 2009
    All Around
    3,149
    what mods are done to the car, what is your ignition ADVANCE/RETARD doing Intake and Exhaust Cam angles. fuel trims...
    May 2019
    14
    the car just have cold air intake and catback. the car run at 22 degress WOT, i try to move WOT gas and nothing happen, intake and exhaust anrket ECUs gle and the car loose HP for both ways... i dont know if hit any limiter but just adding 2 degrees on ignition advance is the only thing good for this car... from 334hp to 356hp on dynojet. im not expert on this HPTUNER program and i want to learn it, i already do mitsubishi and subaru reflash and program many afterma but this is totally different
