Results 1 to 4 of 4
Thread: s10 V8 swap
    Aug 2019
    2
    s10 V8 swap
    ok, so my 0411 swapped pcm has the 12208322 OS in it. I'm running an L31 350. like an idiot i licensed the black box which ended up being garbage, then licensed my 0411. so as you can imagine a rewrite isn't really my favorite option right now. so, since i cant seem to find a tune in the repository with that OS on an L31. my question is can i select ohv 5.7 on the dropdown, change the cylinder count to 8 and fix the firing order? then manually go through and copy over fuel and spark tables from an express van? i know theres a lot more to be adjusted than that. but will it read the 4x crank properly? Also is that going to properly control my ignition module? Or am I just up shits creek here buying another 2 credits?
    Aug 2019
    2
    to answer my own question, it does work. I got it running today
    Jul 2016
    4
    You should also change the cyl volume. That directly effects the VE table. I believe and could be wrong that the pulldown tab for displacement does not really do anything.
    Quote Originally Posted by Badreligion View Post
