Results 1 to 6 of 6
Thread: How I Entered Data for Deatschwerks 78lb/hr Injectors
    Jun 2018
    16
    Hello all this is how I did it. Not a pro so not labeled as "how-to." This was done after installing https://www.deatschwerks.com/18u-00-0078-8. Their injector tuning data is available on their website https://www.deatschwerks.com/ford-calibration-summaries. I selected my engine type/year and injector model https://www.deatschwerks.com/sites/w...-%2018U-78.xls.
    Most of this is copy any paste however make sure the units are the same. Also notice DW refers to High slope while ford lists this as High flow (opposite relationship from stock tune, stock Flow Rate Low was a higher number and vice-versa)
    For the rest of these just know you can click on the unit type i.e.Volts and change the preset points.
    Hope this helps someone out there.pressure2.jpgvoltage.jpghigh slope.jpgbreakpoint.jpgvoltage2.jpglow slope.jpgbreakpoint2.jpgpressure.jpgmultiplier.jpg
    Oct 2016
    Poland
    1,743
    Quote Originally Posted by suprmario96 View Post
    Also notice DW refers to High(pressure) slope while ford lists this as Low flow(high pressure)
    Are you sure about this?
    Jun 2018
    16
    nope, logging showed that difference right away. I swapped them and was within 5% fueling. I'm going to call DW and have them clarify, I think they're using SCT naming conventions or something. Editing my first post to show the right way.
    Mar 2010
    New Orleans, LA
    630
    you have it correct now
    although most injectors have a low slope higher than the high slope alot of larger injectors have poor low pulsewidth control which makes the low slope lower than the high slope
    Jun 2018
    16
    Quote Originally Posted by decipha View Post
    thank you sir, that makes sense, was just having trouble with what each party calls the same parameter.
    Oct 2016
    Poland
    1,743
    good, now it's correct.
