Results 1 to 10 of 10
Thread: WOT Shift Speed vs Shift - Normal Table questions
    Aug 2019
    Las Vegas, NV
    12
    Post WOT Shift Speed vs Shift - Normal Table questions
    Hello,
    I have two questions regarding the WOT Shift Speed vs Shift - Normal Table.
    Here are the parameters:
    2>1 | 19
    3>2 | 36
    4>3 | 59
    5>4 | 76
    6>5 | 107
    7>6 | 313
    8>7 | 313
    1>2 | 23
    2>3 | 42
    3>4 | 63
    4>5 | 81
    5>6 | 94
    6>7 | 313
    7>8 | 313
    Question 1:
    How is the transmission supposed to upshift 5>6 @94 MPH and downshift 6>5 @ 107 MPH ?
    Did the tuner make a mistake with this setting ?
    Question 2:
    With these settings, will the vehicle ever go to 7th or 8th speed at WOT ?
    Thank you!
    Aug 2016
    588
    1: Yes
    2: No
    Aug 2019
    Las Vegas, NV
    12
    This modified tune is from a 2015.5 GM truck with the 6.2L (L86) engine and 8L90e transmission. 7th and 8th gear are disabled to make sure that the truck never goes above 143 MPH.
    However I still don't understand why they would program the 6>5 (112 MPH in stock tune) downshift at a higher speed than the 5>6 (99 MPH in stock tune) upshift. Can someone shed light on this?
    Aug 2016
    588
    Yep. Kinda weird. If you stay full throttle past your upshift in to 6th at 99 and keep climbing at full throttle you will get a downshift back to 5th at 112....locking you into a 5-6-5-6 cycle at full throttle I guess. The 2015.5 had a 135mph limit though....
    Aug 2019
    Las Vegas, NV
    12
    Do you happen to know if there is a parameter that you set in VCM editor that doesn't allow the vehicle to go above a certain speed ? If so, could you please tell me where to find it ?
    Aug 2016
    588
    Under Speedo>Limiter>Limit by fuel the factory set 2015.5 L86 8L90E rigs to 135mph. But if you don't change the trans shift settings you will be stuck in the above mentioned 5>6>5>6 loop at 112 if you hold full throttle.
    If you want to increase the limiter above 135mph you need to also change Speedo>Limiter>General>Source from GMLAN to Calibration....and prepare for the driveline to come apart and abuse the bottom of your rig. If the driveline does not fly out a 2015.5 L86 Yukon Denali will push at least 135 with very mild tuning...not that I would know
    Aug 2019
    Las Vegas, NV
    12
    Thank you for your feedback. I am actually going to limit the max speed to 110 MPH... I don't want the truck to go above that speed.
    I am also going to fix the 5>6>5>6 loop.
    Do you happen to have a factory tune for the 2016-2017 Cadillac Escalade or Yukon ? i am curious to see if the tune addressed this issue from the factory.
    Thank you!
    Aug 2016
    588
    I have loads of 15 6speeds, 15.5 8 speeds, and 17 8 speeds but, you can't actually read a 17 trans tune....After you have the TCM T87A unlocked and you plug in to read it (you have to be connected to the internet) you just get a standard GM stock trans tune from HPTuners via your internet connection.
    Maybe the repository has a 16 8 speed you can check out. I am getting curious what you will find.
    Aug 2019
    Las Vegas, NV
    12
    Looks like the 17 8 speed has the same settings
    This is pretty strange. Do you think there is a method to the madness ?
    Aug 2016
    588
    Actually, now that I think about it...
    2017 L86 8L90E Yukon Denalis (with stock TCM calibration) were hitting a 116mph limiter (probably BCM) with no tuning. Switching the limiter source from GMLAN to Calibration allowed them to hit the factory PCM limit (135mph). I (or whoever was testing them never experienced the 5>6>5>6 loop that the 2015.5 shift tables seem to suggest.
