Results 1 to 8 of 8
Thread: Anyone hear of the map sensor hi resolution pid? Where do I find it
    Jun 2018
    609
    I was told people are using a Hi Resolution pid for the map sensor? It helps for measuring boost properly on GenVs I'm guessing. I can't get proper boost readings on GenV stuff and was told this might be why.
    May 2003
    South FL
    1,366
    The latest version of HPTuners scanner has a math PID for boost which is accurate. I've compared it against my hi res signal for MAP and it matches. In fact, I had to monitor hi res MAP or manifold pressure for it to populate data. The Boost PID does math and takes the barometric pressure, subtracts that from hi red MAP and then converts the KPA value to PSI.
    [email protected]
    Owner/GM Calibrator
    Jun 2018
    609
    I had to update my HP to get it I guess. I can select it in my channels now after going to 4.4
    Mar 2010
    Texas Hill Country
    3,299
    MAP - Hi Res has been in the channel list for years.
    Manifold Absolute Pressure - Hi Res
    Jun 2018
    609
    Weird, I couldn't get it to pop up until I did the update.
    May 2014
    7
    I have the newest version and the math pid for boost is not accurate for me. The math pid does not use hi res map, just uses regular map. Solution to this?
    May 2003
    South FL
    1,366
    Quote Originally Posted by turbo monte View Post
    How did you do your math?
    I have the hi res MAP signal. Then I also have Baro signal. I subtract Baro from Map and then convert the value into KPA and it matches the Boost Math output for me. I'm using version 4.4.
    [email protected]
    Owner/GM Calibrator
    Jul 2021
    I'm on scanner 4.10.4 and my boost calc uses regular MAP and not Hi-Res. It was showing low boost as well using that calc, using the Hi-Res on a custom calc instead seems to show correctly.
