Results 1 to 5 of 5
Thread: turbo 5.3 blowing white smoke
    Jun 2019
    13
    so i took the truck out today to do some data logging and did a small pull while getting on the freeway and truck went pig rich and wouldn't let me accelerate past 4500 and was bogging out so i got off the highway and everything was running fine i pulled into a parking lot to save the log and let the truck idle for about 3 min then turned it off and did everything i needed to on the computer and turned the truck back on and it started blowing white smoke out the exhaust so i popped the hood and noticed i had a lot of smoke coming out of my blow by also coolant level is where it has always been and oil pressure was good around 40psi at idle any ideas?
    Sounds like a broken piston.
    Yep, you broke stuff. Time to open up the engine.
    Advanced Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    770
    Do you have a catch can? Or are you pulling vacuum from the valve covers into the intake? Still have PCV ?
    2005 GTO, TrickFlow 225, Magnuson 2300, 4L80, 4 link 8.8
    2013 Silverado 5.3, 6L80
    Jun 2019
    13
    Catch can
