Results 1 to 10 of 10
Thread: 2017 GT twin turbo hard start wont idle and no Lambda EQ signal.
    Tuner in Training Alxxpress's Avatar
    Feb 2015
    Houston, TX
    20
    So my first issue is the lack of Lambda signal, anyone ever see this problem before?
    Arizona
    242
    Have you checked your fuses?
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Feb 2015
    Houston, TX
    20
    Any idea what location?
    Arizona
    242
    I had the same problem once. It ended up being a fuse. I just cant remember which one. But it cut power to the O2s
    Feb 2015
    Houston, TX
    20
    Hey man thanks, I'll post a question for a diagram.
    Arizona
    242
    Check fuses 38, 40, 42, and 44
    Feb 2015
    Houston, TX
    20
    Got power at fuse.
    Open up your scanner and go to Vehicle tab at top of screen and select Repoll make sure you connect to the vehicle first or it will be grayed out. Try that and see if it works
    Quote Originally Posted by Alxxpress View Post
    Got power at fuse.
    Apr 2018
    605
    Your car is in Open Loop due to a fault. It won't have any WB EQ feedback..... Find the fault, are there any codes?
    Also why do you have Throttle Angle Max=1 degree @ 1000rpm?
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    I am having a similar issue did you get this solved?
