Results 1 to 5 of 5
Thread: Stock 2002 Corvette wideband
    Aug 2019
    7
    Anyone know if possible and where can a wideband be added on the stock exhaust system?
    I live in Bakersfield CA so can't do long tubes
    Nov 2009
    All Around
    3,149
    its best after the header collector, x pipe is good
    13,564
    You may just have to remove the factory o2 sensor and tune it with the wideband in open loop, then remove it when you are done and go back to closed loop.
    I know it's pretty damn tight under there and welding in another bung before the cats is likely not an option.
    Aug 2019
    7
    Not sure if xpipe will be ok for smog
    Aug 2019
    7
    Thinks its even worth it for a wideband?
