Here is a short log file when the motor wouldnt start
If you go to the first O2 spike (green) and compare the two banks one is .7 volts and the other is .08. Also the LTFTs are way off from bank one to bank 2. Could this be the reason for the no start and what would cause this
In another file where the motor is running the 2 banks of O2s are almost the same but the fuel trims are still way different.
Whnewidlemoresparkstart.hplnewidlemoresparkstart.hply wouldnt they be the same
