Hi guys,
I have 2008 C6 Z06 with a stroker LSX 454 heads, cam. The car is already tuned for WOT, however, my tuner is not able to figure out how to fine tune the idle and the low speed (parking lot) driving. The car keeps bucking, surging, wanting to stall at low speeds and it actually does stall at times. Also, when I rev it in idle the RPM drops to near 0 and wants to stall but keeps trying to search for the idle speed until it finds it and stabilizes. Its nothing mechanical, I checked everything, even changed the TB, plugs, wires, tensioner, cranksahft position sensor, ignition starter, and MAF sensor. I had other cars tuned by the same tuner and when it comes to big cams, he is not that great. His WOT tunes are perfect. His boosted setup tunes are also amazing but when it comes to big cam full NA setups, he is not able to tune for drivability. Nothing and no one's perfect I guess.
I know there are lots of setups out there that are running way bigger cams that are much tamer and more drivable.
My cam is 248/256 .662"/.662" 114LSA +4
I have attached a log file and the tune file.
I would highly appreciate any help I get on this. I hate driving the car and would like to drive it more but I need to fix this first. Been trying to find a solution for the past few months.
Thank you
