Results 1 to 14 of 14
Thread: 18 5.0L Hot start stall
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    284
    I have an issue with a hot start stall in an 18 car. It has a PD supercharger, if you breathe on the throttle it continues to run, I've tried all sorts but to no avail. I see the odd random Mustang forum with this issue, any fixes?
    Jul 2017
    529
    Have you added a little idle air?
    Jun 2009
    Melbourne Australia
    284
    Tune attached, I have added idle air but will try more. The vehicle is PD supercharged, the file is my own build for a Harrop 2650 based on the stock OS. The car has good readability and power, hot start is the only issue.
    Jun 2009
    Melbourne Australia
    284
    Quote Originally Posted by MRRPMBRP View Post
    Added more but made no difference, I notice the throttle source is 16 when it stalls on hot start but switches to 9 when you touch the throttle and it runs.
    Jul 2017
    529
    Just looked at your log, throttle is open, timing is there, air is flowing, A/F is ok, I'd be looking for an air leak (vacuum)
    Jun 2009
    Melbourne Australia
    284
    Glad we are seeing the same thing from that respect. Whats the logic behind an air leak relative to hot start only?
    Oct 2016
    Poland
    1,730
    Anything done to the fuel system?
    Try to play with cranking spark, -10 might be way too retarded for power adder.
    Jun 2009
    Melbourne Australia
    284
    It starts and runs for 2 seconds, you can see timing adding, +15-20 degrees, I did try adding 5 degrees with no change. There isn't a lot of emissions retard on a hot start.
    Jun 2009
    Melbourne Australia
    284
    Quote Originally Posted by 4wheelinls1 View Post
    The spark has well and truly recovered at good rpm prior to the stalling,
    Jun 2009
    Melbourne Australia
    284
    Jun 2009
    Melbourne Australia
    284
    This is a different car with the same mods, and tune, it is less pronounced but will stall on hot start if left for 2-4 minutes on the first attempt but will start the second attempt. I'd bee keen to know if anyone can see anything in the log that look different.
    Apr 2022
    1
    Did you ever figure this out? Having the same issue on a harrop 2650 on a 2016 GT, After its hot car refuses to start
    Feb 2017
    TX
    761
    In Spark Advance, you can adjust your cranking spark along with CSER spark to advance timing a little more. IATS are 150* causing 7* to be taken away just from the heat soak.
    You can try adjusting your Feedforward Control in the ETC tab if throttle body size increased significantly.
