Originally Posted by
EmmerichLSx
Just going through the Tuning Shool book on Flex Fuel Tuning, when adding a flex fuel sensor and selecting "sensor" in the drop down menu for flex fuel, the book doesn't touch on how to set up the Stoich table. It has you fix up the PE Spark Advance Correction Mult vs Composition table. I read somewhere to set the Stoich table to gas settings all the way accross, that would leave your EQ ratio the same no matter how much alcohol it's seeing. I can't find anything more on this, so do I need to set up the Stoich table for flex fuel or just leave it gas all the way? Thanks.
