hi im new to hp tuners ,i got it thinking my tuner would make a few tunes i can change street track etc.well past 2 days ive been doing more than that,attached
is my tune file it is not original its the last tune he put on it,the car starts idles 12.0 rev goes 16.0 super rich idle lean if i tap throttle log shows kr if i touch the throttle barely,tried pulling 15% from ve table and 3 degrees no change ,the car has the following mods
sloppy stg 2 cam ,ported 853 heads,pac 1218s,ls6 intake,ngk7 plugs ,gt45 turbo ,air to water intercooler,decapped truck injectors 80lb i think,340lph pump and pump 93 only no e85 here.also a efi source 3 bar map sensor and is suppose to be speed density i think,
the car is a 99 corvette 5.7 a4 trans circle d 32-3600stall.
hes super busy and canr get to it for a while and i want to get it working,it actually ran and drove with the 1bar map and decaps with the turbo no boost.after new 3 bar map thing its dead put in gear no power idles like crap very rich wont move just dies its junk lol.any help or advice the tune is attached or if someone has a similar set up im all for copy paste save write hahaha,thanks mike
something is off and i cant find it
