Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: 5Th Gear no power
    Mar 2019
    16
    5Th Gear no power
    I have a 2017 Camaro SS that is pro charged. Whenever I enter 5th gear on WOT the car dies and doesn't really recover. Anyone have any ideas? Torque management is disabled. I have attached a 1\4 run from last night.full pass.hpl
    Oct 2013
    211
    You start losing fuel pressure in 4th gear around 6200 rpm, you are commanding an overly rich a/f, leaning it out a bit will help with that. your eq error gets up to 14% and at the top of 4th gear your a/f goes to 10.0
    13,559
    Bummer, he can't even log boost with a 1 bar map nor is he logging knock retard or any torque channel to see what it going on.
    I highly suggest you don't disabled torque mngt if you know what is good for you. Especially the peak torque table.
    Mar 2019
    16
    Thanks will try leaning it out a bit on the top end. As far as boost I log it externally, I peak 10.4 around 5500RPM. And I have started to log some torque channels not sure why I wasn’t before...
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by hunter3763 View Post
    Add soi and eoi as well.
    What's the fuel setup on this car?
    Mar 2019
    16
    Quote Originally Posted by sevinn View Post
    Will do thanks! Supposedly LT4 im hoping the shop actually did it. I regret not doing it myself everyday... I guess well find out when I lean it out a bit and make a pass again if fuel pressure is still dropping ill check the injectors and high side to make sure they were changed. They also say they did the in tank pump but I highly doubt they did.
    Aug 2014
    Central, LA
    737
    They could have done the work but never tuned for it, don't fret too much. If it really is an lt4 setup it should be able to keep up with your 10psi on 93 no problem if the settings are correct. Care to post the tune?
    Mar 2019
    16
    Makes sense thank you! Here it isAdjustments use this.hpt
    Aug 2014
    Central, LA
    737
    So just to clarify, do you have lt4 injectors, hpfp, and intank?
    Mar 2019
    16
    Supposedly he put all of that in. I want to believe he did because I would probably have run out of fuel earlier in the run?
    Aug 2014
    Central, LA
    737
    Just checking because some of the values in the tune aren't utilizing full potential of the parts.
    I've made some changes to make your lt4 injector and hpfp settings match that of a 2018 zl1. The flow data was there, but the column axis was incorrect on several of the tables.
    You can increase the hpfp requested if necessary if the lowside will keep up beyond what's in this table as well.
    Adjustments use this_lt4settings.hpt
    Mar 2019
    16
    Thank you very much I appreciate it a ton!
    Mar 2019
    16
    So I went up to the track today with a revised tune. Fuel is much better but I'm detecting some knock during the pass I believe it's false what do you guys recommend for sensitivity for a procharged car with headers?pass 2.hpl
    Aug 2014
    Central, LA
    737
    Your knock sensors are already desensitized a good bit, but it may be a good idea to 0 out your static retard tables. I would log soi and eoi on your setup as well.
    Mar 2019
    16
    Anyone have any new thoughts on this I’ve tried everything now and have a feeling it’s something stupid I’m maybe missing?
    Dec 2015
    Miami,Fl.
    290
    It just takes some time. Keep dialing in your fuel till your wideband matches what your tune is commanding. You should be aiming for .85 at WOT.
    2023 Ford Maverick 2.0T AWD
    Dec 2019
    48
    Quote Originally Posted by HeavyChevy305 View Post
    Running .85 at WOT on 10psi of boost seems abit hot no? Thats what I have my NA setup running at currently.
    Dec 2015
    Miami,Fl.
    290
    Quote Originally Posted by BDPhoto519 View Post
    .85 is considered safe on a boosted DI engine.
    Aug 2014
    Central, LA
    737
    Give us some fresh logs. Let's see what it's doing
    Dec 2019
    48
    Wow... I would of expected much richer, most of the big 5th gen tuners online have been recommending closer to .78 I found. What do you typically run for NA setups then?
