Results 1 to 3 of 3
Thread: 2006 gto rear mount gt45 basetune from na tune?
    hello all,i have a 2006 gto i put a rear mounted gt45 on
    im looking for some one to give me some pointers on ajusting my na tune to turbo
    motor is ls2 6.0 bored .010
    forged mahle pistons
    forged rods..
    stockcrank
    texasspeed torqurv2 cam 232/234 600/600/112
    ported 243 with 66cc chambers
    60lb deka injectors-not installed. do not have data for them
    compression is 10:1
    and rings are gapped for turbo.
    and 340 fuel pump.
    the intercooler/charge pipe is 2.5 inch to 4inch whereit meets the MAF
    my question is can u run the stock maf?
    im learning as i go,anyone know any goodlstuners around buckhannon wv?
    this ismy current tune,sorry for being such noob but itmakes 425rwhp 414rwt my goal is 600 hp.
    13,559
    Apply the 2 bar OS upgrade that you have under the OS tab. This will give you a few more tables that you need.
    It will give you a boost VE and also give you a boost eq ratio for fueling.
    Get the data for the injectors or just toss them in a garbage (sell them) and get good injectors with plug and play data.
    You need to purchase a 2 bar or 3 bar MAP sensor so you can log boost.
    Once you have the 2 bar OS applied you must alter the power enrichment EQ ratio and the boost EQ ratio to values that are safe for boost. Like right now your current EQ ratio is asking for like 12.8-13.0 AFR, that's too lean. Aim for 12.0 at low boost and 11.0-11.5 once you are into it a couple pounds.
    Your timing curves need an overhaul too. No longer can you get away with 26-28 degrees of timing. Likely need to cut that in half and run 12-16 degrees depending on boost levels.
    If you're asking me, I'd ditch the MAF completely and run speed density only with a separate IAT sensor installed. You can run the MAF but it may be likely that you will run out of room in the MAF curve for fueling. Also if the MAF is already installed and it houses the IAT sensor already, you can still leave it in place and run speed density only.
    Jul 2012
    Florida
    1,456
    On LS1 Tech website, there is data for those injectors.
    2013 Silverado 5.3, 6L80k 8.8
