Results 1 to 9 of 9
Thread: 2017 6.2l 1500 Sierra / Rough Idle possibly bad cats? codes P0420 P0430 P050D
    Jun 2017
    NJ
    15
    I have a 2017 6.2l 1500 Sierra with 1 7/8 ARH headers with ARH 200 cell high flow cats. I have a CEL throwing codes P0420, P0430, P050D. Upstream o2 sensors are disconnected shop did the tune and I had no CEL or issues untill now. At idle both downstream o2 sensors are around 0.7v and constantly dropping to 0.1v once a second or two consistent with the rough idle. Any ideas? If anyone needs me to log anything or some more info please let me know thanks.
    Edit: thought I included this Truck has 82k miles headers and hi flow cats were installed at 5k. also idle is around 630 rpm and should be around 900.
    13,570
    The front o2 sensors shouldn't have been disconnected, that is not a good sign if you ask me. That's a pretty stupid idea to disable all o2 sensor control, fuel trim control and closed loop operation.
    If the front o2 sensors are not working, those cat codes will always be there.
    Please post the tune file you have and you really should put the upstream o2 sensors back in the exhaust.
    Sep 2014
    30
    Quote Originally Posted by Wildlyfe200 View Post
    Your upstream O2s are removed/tuned out? I'm guessing you mean your post-cat sensors are removed. I know on my 2018 I had to leave the rear sensors physically connected and just tune them out. When I removed them entirely it caused all sorts of codes. I don't think it caused a rough idle, but I don't remember. I left mine connected and just zip-tied them to the frame. The P050D "rough idle" code could be anything. Did you try resetting the codes?
    Jun 2017
    NJ
    15
    I have not had codes for 80k miles and the Truck has ran great. ARH headers have no spot for the front O2's. here is the tune file
    https://www.dropbox.com/s/owcij3ekov...-%207.hpt?dl=0
    Jun 2017
    NJ
    15
    Yes I have the same set up as you only rears o2's connected. I have a feeling it is another issue nothing with the tune Vehicle has been running perfect for 80k. Yes I reset the codes and they came back on.
    Nov 2009
    All Around
    3,149
    also log your individual cyl for misfire
    Jun 2017
    NJ
    15
    I will do that today and report back i did a tune up but that did fix the problem.
    Jun 2017
    NJ
    15
    Problem fixed it was a misfire problem. This morning the CEL went off by itself after it ran for 5 minutes. Last night it ran for 45minutes like crap even after the tune up. I guess it was still in "limp mode" untill it ran another self test. The tune up did it but i did not reset DTC codes and assumed the problem was still there because it was running rough. I logged a 1hr drive this morning no misfires.
    Nov 2009
    All Around
    3,149
    there you go
