Results 1 to 4 of 4
Thread: limiters
    limiters
    im beginning to familiarize myself with the limiters. Im currently looking at the maximum engine output limiter. it has the 5 engine states on the rows and rpms on the columns. Im under the impression the 5 engine states are.
    0- transition
    1- low density
    2- low/med density
    3- med/high density
    4- high density
    is this correct?
    Basically looking at this map for example lets say 2000 rpm@ state 4 the maximum commanded fuel rate my engine will receive will be 125mm3, assuming their isn't another lower limiter.
    Advanced Tuner Jim P's Avatar
    Jan 2018
    Everywhere
    949
    Reverse your 1-4 and you got it.
    0 - transient
    1 - high air density
    2 - med/high air density
    3 - med/low air density
    4 - low air density
    I was looking at my log and noticed I had a limiter pulling back some of my timing. And all it said was combustion manager. Any idea what direction I should look ?
    Jan 2018
    Everywhere
    949
    Post your log and tune.
