car is a 98 regal gs which has 2.93 gears and approx 1800rpm stall stock
swapped out for 3.29 gears and a ZZP 2500 stall
made the following changes in my pcm
Calculated gear from 3.29 to 3.69 - auto scale (which changed all mph by 89%)
TCC MIN TABLES - added 15 in all spots
TCC MAX TABLES - added 10 in all spots
Got rid of lockup in 3rd gear (unsure if i want to be doing this)
I believe this is all that needs to be done, i have heard of people change the drive sproket ratio (since it is now 1.0 and not 1.121) but i guess people now recommend to change the calculated gear instead for its autoscale feature...?
Just want to make sure its all right.
Thanks!
