car is a 98 buick regal gs.
I'm having an issue at idle where the car wont move (once warmed fully) unless i give it some gas then it finally "catches" and then moves. it seems its not getting any fluid unless the pump goes faster. im going to switch the filter tomorrow to see if it was partially plugged but it has come to my attention that i may have a leaky input clutch piston, and by revving the car the increased pump pressure is overcomming the leak.
what im wondering is if i can increase transmission pressure, but not at the shifts, all the time. im wondering if the force motor current table can do this. it appears not as the table is under "shift properties" but i figured id ask.
