Results 1 to 10 of 10
Thread: Help with startup Airflow
    Oct 2013
    34
    Please help, this is driving me crazy lol. Gen3 LS1 btr stage 3 cam. LSA supercharger, NW102 throttle body. Manual trans
    When I start RPM goes high then dips low. Log and tune postedidle air test.hptidle flare.hpl
    13,569
    If it's speed density only, make sure you fail the MAF correctly.
    Oct 2013
    34
    Ok I made sure its in SD only. I am not runnig MAF. I will gladly pay for help!
    Oct 2013
    34
    Got the startup flare to not be so dramatic my increasing the Startup flare control table. still like to dip though. RAF table is correct now. Any advise? I just wanna drive without it wanting to die
    37
    Increase timing
    Quote Originally Posted by brycedrue View Post
    I would check your timing table. I have same cam in auto and my tunes are posted on this forum. My car idles fine and at startup idle is 950 and slowly comes down to 750 per tune as it warms up at idle. In gear idle is set at 705 rpm. I am running stock air box and filter.
    Steve
    What exactly needs to be done to fail the MAF correctly?
    Dec 2018
    Chas, SC
    Post your tune file.
    Oct 2013
    34
    its posted
    Dec 2018
    Washington State
    182
    Not failed correctly
    Oct 2013
    34
    [attach]92596
