In the scanner after i connect to the car and log the tps show 11% . if i hit throttle it goes up ,but if the car is on at idle or off key on not touching pedal scanner
shows same 11% or 11.7%.
Is this normal ? im thinking its not and should be at 0 ,this may be part of the tuning issues im having.
being new to this fun stuff i figured id ask. what do you think?
