Results 1 to 3 of 3
Thread: need some help with a tune
    Aug 2019
    Cincinnati, Ohio
    11
    this tune is for my dads Service truck. its completely stock, he would like a little more power and fuel mileage. I'm still learning on tuning any help is greatly appreciated
    oringal tune out of truck.hpt
    new tune for truck.hpt
    the original tune is the one i pulled out of the truck and the new one is a tune i compared to 6.0 ss tune. But with the new tune when you hit a hill it uses power and drops speed.
    The truck weights around 12,000 lbs.
    13,565
    The new tunes air fuel at full throttle is too fat. Do the math, it's 14.68/1.300 = 11.29 AFR commanded. Aim for 12.0-12.2 on pump gas to still be safe. It may pick up a few ft lbs of torque but otherwise you are limited by the stock engine and camshaft. The stock PE eq ratio was better suited, just remove the rpm/time delay and adjust the pedal percent how you want it.
    No real power gains are going to be made without power adders. The 6.0 SS also uses a high compression LQ9 and not the low compression LQ4 like this truck has. I'd be careful how you alter the timing curves because you could make it knock worse and pull power.
    Fuel mileage won't happen either, it's a 12,000lbs brick going down the road. I'm sure it's gets 9-11mpg on the regular and that will never change.
    Aug 2019
    Cincinnati, Ohio
    11
    Ok like i said i appreciate it i will change that stuff and let you know
