GEn 3 ECM vs wiring harness
I bought a harness and ecm off of marketplace and were told they were off the same vehicle. The Harness had the Isolated ground O2 sensors with the SQUARE grey connectors. When i scanned the pcm and downloaded the tune it was for an 02 Silverado 2500 with a 6.0 which I though was case grounded. Is there a way to check that the PCM will read the sensors correctly?
Starting in 2001 6.0L truck engines (LQ4 & LQ9) began using isolate ground front (upstream) oxygen sensors.
