Results 1 to 16 of 16
Thread: Need help with tune
    Aug 2019
    19
    Need help with tune
    Can I send my data log to someone so see why my c6 ls7 bucks surges at very light to coasting ,does it at all rpms more at low rpm 2 tuners can?t figure out comp cam longtubes halltech Cali ported fast 102 intake ported stock throttle thanks guysmani BMS drivabilty 9.hpl
    Aug 2009
    Calibrating
    3,373
    Most likely fuel off and or timing too agressive
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2019
    19
    ya he pulled back timing still same thanks
    Aug 2018
    293
    Got the tune file? The biggest thing that helped with mine was getting the idle AFM table correct in the "gears 1-6" rows. Couple that with ensuring your spark isn't jumping around and your DFCO is set properly if still active. Those things made a really huge difference for me. Timing alone didn't fix it in my case.
    Aug 2019
    19
    Surge
    Quote Originally Posted by RobZL1 View Post
    Did u see my file
    13,564
    That is the log. He wants the calibration file, aka tune file.
    Aug 2019
    19
    File
    Do you think the tuner will give to me ??
    13,564
    No idea, you'd have to ask the person.
    If they can't figure it out, then they should give you what is yours because you paid them to fix the issue and they clearly can't.
    Nov 2009
    All Around
    3,149
    post your actual tune
    Aug 2019
    19
    I’ll go there Monday and ask for the tune file as well as the wide open throttle file Thanks a lot guys. Forgot to mention that I went from the ngk laser iridium itr7 went down to 6 little hooter plug 7 we’re gapped at 40 6s I gapped to 35 same drive issue thanks
    Jul 2019
    Baytown, TX
    118
    Do you have HP tuners software and the interface (e.g. MPVI2) ? If so, you should be able to take your laptop out to your car, read the tune directly from the car, save and post up the file if is not locked by the tuner.
    Aug 2019
    19
    loaded file
    Aug 2019
    19
    Nov 2009
    All Around
    3,149
    please list all your parts in detail
    Aug 2019
    19
    mods
    Quote Originally Posted by SultanHassanMasTuning View Post
    comp cam,halltech cai, ported stock throttle, fast 102 ported intake, long tube headers, no cats. 160 thermo
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Look at your spark and VVE table in the 3D view. Both of those should be corrected before you go changing other things.
    2013 Silverado 5.3, 6L80k 8.8
