Cant get this girl to maintain an idle to save my life. Idle is set at 975, but she hunts roughly 200 rpms. will post a log tomorrow, but below is a rundown of what I have adjusted, then put back to stock values after not finding any benefit from changes. fuel trims are within 10%...
Small/Large Throttle Commands- maybe i made bigger adjustments than needed, but lowering or raising these field didn't help.
Throttle Body Airflow- think mine is good to go, but tried adding more air down low, NO HELP
All TQ spark & Throttle TQ under the idle airflow tables, spent countless hours on these, NO HELP
to be fair having a better understand on what P,I & D are would help, but it appears you have your desired idle then factors that come into play when the idle is x amount rpms higher or lower.
6.1 based 426
116 lsa 240i 252e 597 lift
