Results 1 to 8 of 8
Thread: New in tuning. Need help in fuel table
    Aug 2019
    3
    Hi
    I just new in tuning i have camaro with ls1 stock engine I didn?t do any thing with pcm i try to start the engine its crank but no start I checked the fuel and spark plug both fine then I found the engine in rich condition so which table I need to adjust
    I changed min fuel inj and reduce it 1.277 to 0.350 but no changes
    13,557
    Stop.
    Never change the injector information if you didn't change the injectors. Those tables should never be touched. Put that back to stock.
    You have other issues if you are getting a crank with a no start condition. Either you have a VATS issues or a major sensor issue like something with the MAF/MAP, crank/cam sensor or similar.
    Without data logs we have no idea. And if you think it's a VATS issue, disable the VATS in the tune file.
    Aug 2019
    3
    Thank you for your help sir
    My tune editor show me VATS :None
    I will try to clean my MAF season and see what happen
    The garage guy told me that the engine is flot
    Feb 2017
    Houston Texas
    67
    Post the Tune file and a log. We can better help if we know what you are working with.
    13,557
    You'll need to try and get a new log. The log you posted is no good.
    Nothing in it is showing any real data, like it didn't connect properly. You should connect to the car again and re-poll for supported parameters under the vehicle tab.
    You can see that lots of channels are reporting no data or incorrect data if things are plugged in. Like the coolant temp and intake air temps are at -38 degrees, that's not right.
    Feb 2015
    Perth, Australia
    974
    did u write entire after VATS disable?
    why is their open circuit for both temp sensors? that will make the car exponentially richer.
    theres no RPM signal on log. fix this first
    Nov 2009
    All Around
    3,149
    if your breakout for airtemp is not connected to need to disable it.
    what modifications are made to the car
    camshaft?
