Results 1 to 7 of 7
Thread: knock sensors
    knock sensors
    Is there a way to make sure the knock sensors are working?
    13,565
    Smack the block/oil pan with a rubber mallet or something.
    seriously? ok would you happen to know where the sensors are located on a 08 4.8 Silverado. under intake?
    13,565
    They are located just above the oil pan on the block on both sides of the engine.
    thanks, the e38 ecm doesn't show a "sensor" it has knock retard (plane angle). is this the right pid to log?
    13,565
    It should just be a regular knock retard channel you can log.
    Re-poll for supported parameters while connected to the vehicle if you haven't.
    thanks for the info.
