Results 1 to 5 of 5
Thread: 09 ctsv transmission swap problem
    hey guys need some help
    have an 09 ctsv lsa w 6l90e
    6l90e died
    swapped over a 6l80e extended the driveshaft and have it on.
    car does not recognize gear selector
    it does go into reverse and drive. have not road tested yet.
    any help as to why it wont recognize the 6l80e gear selector.
    or how to make it work.
    i cant be the only one to try this im sure.
    thanks in advance.
    13,565
    Did you flash the TCM yet?
    The 6L80e TCM won't be a match to your operating system/computer unless you do that first.
    you know i havent, i do have a gm mdi so i will stock flash the tcm and see how that goes. will post results. thank you.
    I swapped in a 1,000hp built CTSV 6L90e in my 2010 SS and was told by Tim King at TK Performance who built it to just swap in my 6L80e TCM and retune.
    Why did you not leave the 6L90e TCM in there and just retune it?
    2010 Camaro SS 781rwhp
    TKR Stage 4 CTSV 6L90
    Circle D 258mm 3400 3B Pro Series Multi Disk
    Kooks Ceramic LT's & full 3in exhaust
    TFS GenX 255's (Polished PAC .660's and Ti-Retainers)
    TSP VVT 3.2 cam
    Smith Bro's trunnion kit
    AEM X-Series OBDII Wideband Gauges
    FIC ID1300x Injectors
    ZL1 Fuel Pump
    DSX Flex Fuel Kit / Auxiliary Fuel Pump Kit
    MM Camaro 5 Wild
    Holley Tall LS Valve Covers
    NGK Iridium IX #7
    HP Tuners MPVI2+
    ProCharger D1X @ 13psi
    to be honest
    I did not want to open the trans.
    Nor did i think it would be an issue.
    assumed a flash would take care of it.
    even w my gm mdi it would not flash, w hptuners it would not flash the 6l80 tcm to 6l90. its a no go that way.
    i may end up going to your suggested route and drop the pan and tcm swap. Thanks
