Under fuel > oxygen sensors is where you can force open look.
However the little description text seems counter-intuitive
[ECM] 2529 - O2 Sensor Ready Voltage: If the O2 voltage drops below this value, the O2 Sensor is ready for closed loop. Set low to disable closed loop.
stock value is 1,795
As it reads, if the O2 voltage drops below 1795 the O2 sensor is ready for closed loop. Then it says, set low to disable closed loop?
I use a value of -1795. Closed or open loop?
In all my scans with a negative O2 value, the PID: fuel system status #1 says CL-normal. I assume that means the car is in closed loop?
Thanks for helping a nooob!
