In the DFCO tab on the left side about 3/4 of the way down is an option to disable fuel cutoff will this choice also mean that I lose fuel cutoff ability of the ECM program at the max rpm limit and thus risk engine damage.
You want the DFCO section further to the right, where you can alter rpm and/or ect to turn off dfco. The one you are talking about is for rev limiting, not dfco.
EDIT: Now that I think about it, you are likely in basic view instead of advanced. Go up to "Edit" and change your view to "advanced" if so.
Thanks I am just learning and my tuner person did as you suggested as he thought we would lose the rev limit ability which would be a bad thing and I just wanted to confirm it. I liked the effect of just turning it off but there is too much risk in that and am still playing with the rpm settings to mimic having it just off but havent got the rpm settings exactly right yet, they are close. Had advanced on and was just hoping there was a simpler way to disable it. Here is a pic of how it is currently set comments welcome.
Ditto to all of the above. Leave the Fuel Cut Enable alone, and change the enable/disable temps to something like 490/489 and/or the enable/disable rpm to something like 8000/7900. That will eliminate DFCO and keep your rev limiter. The three sections or columns in the screenshot are for different things. The leftmost section is for the rev limiter, the middle section is for DFCO, and the rightmost section is for clutch fuel cutoff (CFCO).
The three sections are not directly related. They function independently of one another.
