Results 1 to 9 of 9
Thread: adding ZL1 pump to 17 Camaro SS M6 any changes in tune
    Mar 2019
    40
    title says it. just need to know if I have to change anything. iv heard raise the voltage not just drop it in. just running E85 with headers and ported IM /TB and CAI. Installed because the drive shafts out for solid cradle bushings and Hurst shifter so might as well for future mods.
    Jan 2019
    White Hall, Arkansas
    73
    The FPCM should handle it fine. I don't think you'll need to change anything. Let us know how it works out.
    Mar 2019
    40
    i ended up changing the voltages and flow to the ZL1 specs.
    May 2017
    North Florida
    80
    Quote Originally Posted by JCunningham View Post
    Can you post your changes?
    Mar 2019
    40
    the higher numbers are with the ZL1 pump. i was told to change these on the camaro6 forum. my tuner told me there is more that can be changed but i dont know what it is. He told me to send him the file and he would do it.
    May 2017
    North Florida
    80
    Thanks for responding Is this the tune that he updated?
    Mar 2019
    40
    These are not from my tuner. I looked at the 1LE tune. The 1le has the zl1 pump and the voltages are the same as the SS. So I put them back. The flow numbers are the same thought from 1le to zl1. You also have to change the range numbers up top. I'll explain it better later.
    May 2017
    North Florida
    80
    Mar 2019
    40
    the flow rate needs to be changed above the pressure this is what it should read not the pic i posted above. ill change it above
