Results 1 to 10 of 10
Thread: 68RFE Locked shifts
    Jan 2018
    658
    68RFE Locked shifts
    Probably not many on here running a 68RFE but I now have the ability to provide locked shifts on the 68RFE transmission.
    That is awesome to hear Jim! I assume you are able to do this through HP tuners, or is it with MM3? Willing to share how, or are you a tuner now?
    2010 CCSB 68RFE - HP Tuner self tuned - BD Diesel Protect68 Kit - Transgo HD Shift Kit - 4" TBE Exhaust w/ 17" FTE Resonator - Crower 110lb valve springs - Manton Series 3 Push Rods 7/16x.120 - 12.9 head bolts - Fleece CP3k - 60% Nozzles - Smeding Intake Horn
    Jan 2018
    658
    PM sent to you
    Jan 2018
    658
    I can do locked shifts on the 68RFE for 2010-2012?s on HP Tuners, 2010-2018 on UDC Pro RT/Warp for the Smarty Touch and MM3 as well as 2010-2018 on EFI Live (if I were to ever get a FlashScan V2).
    I?ve been running locked shifts for some time now and I absolutely love it.
    Jun 2018
    Will this work on the 65rfe also?
    Jan 2018
    658
    Don?t know, never looked at the 65RFE. Post up your file and I?ll see if I can locate the transmission section.
    Jun 2018
    Oops sorry for late response, I can post but don't want to waste your time seeing I only have HPtuner & i2 programmer.
    Jan 2018
    658
    It?s fine, post it up and I can take a look and see if I can find the transmission section. If it?s anything like the 68RFE I could set your file to be able to have full lock shifts
    Jan 2018
    658
    You are in luck. I?ll modify it for you and post it later.
    Jan 2018
    658
    crackerjack, sent you a pm.
