Results 1 to 4 of 4
Thread: Transient Fuel Gain Questions.
    The car is a 09 crown vic 4.6 2v with the spanish oak ecm
    In Engine > Fuel > Transient
    I have tables for Gain, Gain at start up, Time constant, and Time constant at start up.
    My issue is it takes around 4 seconds of WOT for my fueling to respond. Lambda stays at 1 during this time. I am wondering if it is the transient tables causing this delay and if so which tables I should modify to shorten this delay.
    Thanks for any insight you can share. I have been reading "The Ultimate Ford EFI Tuning Guide" by Lasota and learning a lot. But I still have questions.
    Oct 2016
    Poland
    1,740
    Insight requires a "sight" which is properly represented with """LOGS""".
    Senior Tuner CCS86's Avatar
    Nov 2017
    Austin
    1,089
    Quote Originally Posted by 09Vic View Post
    No, transient fuel gains will not cause a delay in getting to a "power enrichment" commanded EQ ratio.
    Indeed...
    Its a long log file. Around 10:59 in the log is where it shows.
    Quote Originally Posted by CCS86 View Post
    Thank you. I thought it was more like a old school accelerator pump setting but I had to ask to be sure.
