Results 1 to 5 of 5
Thread: Torque management problem or not?
    ECM E38
    TCM T42
    They used a e38 engine os for the ecm
    used a different os in order to use a 4l80e
    Problem is I thought I deleted all torque management, but notice the etc is acting weird and the timing is being pulled at part throttle. When I log torque management, I am still getting tq management showing for the "trans" meaning transmission. I also logged the torque management advance and you can see it coming in. The car runs like its running against itself or as if brakes are being applied sometimes during part throttle.
    I do not know where the extra torque management is coming from.
    Can you take a look at this rough tune.
    Thx
    PS. wideband was disconnected disregard that afr
    7,628
    Put the stock values back in the tables, Trans > TM > Abuse Mode, and see what happens.
    The abuse mode under the transmission tab only? circled below?
    I did not see an abuse mode under the ecm engine tables.
    7,628
    Correct.
    I'm not fer sure, but it's something like those tables do the opposite of what you'd logically think, zeroing them out makes it think it's always in abuse mode. Or something like that. I've never seen a concrete explanation of exactly how they work but many examples of weird shit happening after they get messed with.
    Advanced Tuner Atomic's Avatar
    Jun 2008
    455
    So did that work?
