Results 1 to 4 of 4
Thread: Tuning LS1 Maf independent of VE
    Hi all,
    I was looking for an old thread but couldn't for the life of me find it (I think it was russ kemp who made it). Anyways I am back to tuning my LS1 and I have shut off the MAF and am tuning VE. I am getting pretty far along with my ve tables that I am about ready to switch over back to maf shortly to tune. I forget how to isolate and only tune the MAF so that the VE does not play into the equation?
    I swear there was a way to do it, and I have searched high and low to find the thread and I can't seem to locate it. Can anyone help refresh my memory?
    2002 LS1 Camaro - (12.9@104mph) 3.73 gears/3600 stall/corsa exhaust/tuned/Ford 8.8 rear end
    1996 3800 camaro-- (13.4@100mph) Heads/Cam/Geared/Stalled/Ford 8.8 rear end
    2008 Chevy Colorado - Daily Driver / Off-Road
    Camarov6.com | Project Cars | 5th Gen Camaro Specs | How-to Guides
    13,565
    Put the dynamic airflow high rpm disable from the factory 4,000/3,900rpm down to like 100/90rpm. Then it would be considered "MAF only".
    Thanks - I thought it had something to do with a setting in there. I had mine still set to 800rpms from when I was tuning it last year as I guess I forgot to set it back.
    And just to confirm, if I had that setting on 800 and it is considered "MAF" only, if I have the MAF set to disable then I still would only be getting VE data correct?
    Nov 2019
    TIGARD
    37
    GEN 3 MASS AIR FLOW METER TUNING MODE
    step1,
    ....SAVE ORIGINAL TUNE
    step2,
    AIRFLOW/DYNAMIC
    ....high rpm disable
    4000RPM/set@100RPM
    step3,
    FUEL/02SENSORS
    ....disable LTFT min ECT
    set min@ max284
    step4,
    FUEL CLOSED LOOP ENABLE
    ....ECT vs IAT max it at 284
    step5,
    FUEL/TEMP. CONTROL
    ....catalyst over temp /DISABLE
    step6,
    DFCO CUT OFF
    ....Enable ECT@105/set to 284
    IM NEW BUT I BELIEVE THIS WILL HELP ......
