Results 1 to 6 of 6
Thread: Large DBW Thottle Body with forced induction, who has had luck?
    We have a 112 on a 2650 here that makes over 1000rwhp and the 112 worked great for about 1000 miles or so then has progressively got worse. We have tried to flip it over and we have the same result with 1516 codes. I have put a video link here of the blade under a WOT pull along with a log and tune file. 2016-mod-55.hptREDUCEDENGPOWER.hpl
    https://www.youtube.com/watch?v=lL5QULBTrZY
    Oct 2013
    211
    This will fix your issue, I cant save the file on my work computer but its self explanatory after this step. You will see p1516 in Engine Diag -> airflow next to 2101
    Aug 2009
    Calibrating
    3,373
    Yep! Add slave and max it out
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Dec 2018
    2
    I dont want to high jack this thread but I am having issues with the P1515 and P1516 codes... The following is a help request that I posted on the HPT facebook help page:
    C5 guys, I need some help. I am getting 1515 and 1516 codes coupled with reduced engine power and no throttle response (limp mode) on my 2001 C5 Z06. I have attached a video of a scan showing tps and tpp info... HELP!
    PS - I originally had a LS3 style TB (Nick Williams 102mm) and heard that it could have been my problem so I had a new TB built by Nick using the stock TB components (also a 102mm).
    Edit - The attached video is with KOEO and with me modulating the pedal. Towards the end of the video (1:05) you can see that the TPS went from ~78% to 0 and then went to 14.7 and held. This the the point at which the TB snaps closed and quits moving.
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    ECM 12940, 41, 42 all need to be fixed and and ECM 2150 needs to be 8191 on a e67 for a 108mm or larger. I run a 108mm
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
    Tuning Addict
    Jan 2015
    6,799
    Nick's upgraded TB motor will fix the problem with the newer bigger TB setups combined with boost, BUT for those looking for perfection - make sure to correctly tune the three tables that jslic posted - they will make a 1000rwhp car drive like a factory car. Thank you Scott for helping us get those
    ~Greg Huggins~
